97 gtx wont start or crank
grimreeper621
i have a 97 seadoo gtx that wont start or even turnover. its been sitting in my driveway for about 3 months, the battery is fully charged. it ran fine the last time i used it and when i got home i washed and flushed it without any problems. i went to start it to winterize it and got nothing. the clock and everything comes on fine, but when you push the button to start it, nothing. if you push the starter again it comes up "HI temp warning" no clicks or anything as if the battery were dead. somebody please help!
Try jumping the starter solenoid. If it starts or cranks then the solenoid is bad, if not then the started could be bad...have it rebuilt.
You must be sure that the battery is 100% charged and ready to go. Try switching batteries and see if that helps.
Compression and plugs are good????
