This machine will pull one person up on plane but willnot pull two up. I did a compression test and both cylinders have 148 psi on each cylinder , took off carbs and looking inside the intake I can see in one the other has a plate covering the hole it will move a little but will not open. what is this , could this be the problem , idles good and top ends good
