I recently rebuilt both carbs and the ski ran great for the first couple of rides. Midway through the 3rd ride it began to run poorly, lacking power over 5000 rpms. Just prior to this we had been in some very rough water and then through a no wake zone prior to stopping for lunch. After lunch we headed home in smooth water and this is when I noticed that it was lacking full power..
Prior to the carb rebuilds I had replaced the following: fuel selector valve, fuel filter and o-ring, grey fuel lines
After this last ride I have installed new plugs but this provided no improvement. One other symptom is if I switch the fuel selector to reserve the ski dies immediately. I am down to approximately three quarters of a tank of gas. I have removed the fuel valve again to check it with compressed air and it seems to operate correctly in both the on and reserve position. The fuel valve that I purchased did not appear to be new. The fuel lines are all connected properly. My GTX has approx 162 hours of run time. I have purchased the Rave valve rebuild kits but have not installed them yet as I want to get it running right first. Any ideas??
