AKnarrowback
Hi guys.
The GTX is running great, I just swapped out the carbon seal for an old style bearing and seal.
One problem I'm running into is after running the motor wide open for a minute or more then gradually letting back on the throttle and bringing the throttle back up again the motor refuses to rev back up. If I let off on the throttle all the way closed and nail it wide open things rev up normal and it takes off like a rocket.
Rave valves are clean, burning brp synthetic, bellows and springs are good, red adjusters are set flush with the rave caps, gas port is clear. I'm 99% sure it is the raves hanging open with the gradual throttle decrease giving me a high port at too low of an rpm, but I wanted to get opinions on it.
What I'm not super familiar with is if the water can valve and rave valve adjustments interact enough to cause this drastic of a running condition. Also, where does everyone run the caps in relation to flush (in or out). I'm guessing increasing the rave spring tension will help the valves close sooner when the throttle is brought down gradual and have them set up to work at the lower rpms to let the motor rev back up without bogging for 10 seconds.
