Why would a 97 GTX keep blowing the 5Amp fuse.
If I replace it, it will not pop when its dormant, push the start/stop 2x to activate the gauges, or when you put the lanyard on.
It will pop after it cranks over 2-3 times or even IIRC when the battery was weak and could not crank over the engine. It only seems to pop when you engage the starter.
When I get home I will see what happens when I disconnect the stator and/or rectifier. I just wanted to see if any one had any other ideas.
