Hey everyone!
It's been awhile since I've been on this site but I am helping a friend work on his 97 GTX and it's acting up in a way I can't figure out.
It's a 787 tired motor but compression is 145 on both cylinders.
Grey gas lines replaced.
Fuel shutoff valve replaced.
Carbs completely rebuilt
gas vents replaced.
When you take it out first thing off the trailer it runs great for as long as you want. Idle, acceleration all fine. When you stop for awhile and let it sit you go back and it will start right away but will not accelerate until you tool around at idle for awhile. It will run fine after you give it some time at idle. Then after awhile it will start to bog and not go past 5000 rpm and finally die and not restart. Has done this 2 times now.
Spark plugs look good. Gas system looks good. Pop offs are set at 34 psi.
Any ideas????
gas vents replaced.
Any ideas????
