roberth2013
Hello forum, bought a 787 from a coworker a couple months ago, he had the carbs rebuilt, all new fuel lines by a local shop, he hadnt ridden it after the repair it was this past winter, anyways i bought it, drained, removed and cleaned the fuel tank spic and span, replaced the inline fuel fuel filter, put in fresh 93 octane ethanol free fuel, fresh battery, put some engine fogger down the spark plug holes a couple days previous, new spark plugs, cranked the engine a few short bursts to move the fogging oil up and down the cylinders, spark plugs in, cranked it over choke out, after a few minutes nothing, pulled the plugs, cranked it no spark, checked the fuses, the one in the ECM was blown, popped a new fuse in, blew instantly, bought another ECM, still no spark, fuse in the solenoid, blown, bought new coil, urekaa, i got spark, cranked it over, nothing, shot some ether free starting fluid though the hole in the breather, fired right up, and would run as long as i sprayed fluid in, fuel pumps are working, when i went to open the fuel tank cap,, i heard hssing from suction, let it set a day charged battery back up, tried starting again, nothing even with starting fluid, put an inline spark tester no spark at all, checked all fuses,, all good, checked the ground, kinda iffy put an entire new groundwire setup in place, still no spark, any ideas other than the pick-up in the stator case, thanks for any input
