Alright so I’ve posted on here before about the issues with my ski and it never really got resolved so here I am again. I’ve made good progress on the rest of my pwc but it still struggles to run. I pull the choke and it’ll start fine and I give it a few seconds then let go of the choke and it’ll run for 10 seconds or so then die. To answer the questions everyone will ask: carb has been fully rebuilt with only oem parts and I’ve checked it to make sure it’s done correctly, it has good pop off pressure, the fuel pump can hold a few psi indefinitely, I replaced the fuel filter, I replaced the fuel petcock and it isn’t leaky, all fuel lines have been replaced, and I’ve got the carb set to factory settings, I’ve also ran a hose to another fuel source and nothing changes. Mind you this engine is also fully rebuilt. It’s got a new crank, new pistons and overbored cylinders and everything between.
I have some suspicion that my fuel lines could be the culprit (they are the transparent kind you can get from a ton of places online) as I was told they don’t allow the fuel pump to work properly so I changed out my pulse line to higher quality stuff and it worked better but still no running. Can anyone help?
-Update- I replaced the fuel lines with better quality line and it helped a little but it still has the same issue.
