97GSXnitemare
Hello everyone..
I have a 97 GSX as well, it started out bogging down and no high rpms ran about 15 or the lake, brought it back to the shore, tried to adjust the raves, only to find out that one was stripped out in the threads and not opening at all. And had a hole in the exhaust freeze plug i believe what it is called. Fixed that to, and well put the thing back in the water this yr and it wouldn't even start. backfire spit and cough. So i got some rebuild kits and for the carbs, replaced the gray fuel lines, still wouldn't run. checked compression read 60 psi on both cylinders. i thought i'd give it a shot and just for the heck of it and replace the plugs, only thing i haven't done yet. and Bam started right up and ran good on land. took it to the water and it would run like at 7050 Rpm's and only do about 43 if i laid down on the bike. and from what i've read this bike should do about 60+, So where do i go from here??? Carb Adjustments? or wear ring? or Rave valve adjustments? sorry for the book but figured i'd get it all in there at once. Thanks for any help with this issues.
Butch..
Butch..
