97 GSX electrical starting issues
Redrobin9484
Hi guys,
Hoping someone can help. I have a 97 Gsx limited that I get nothing out of the starter switch. Thought it might be the computer, so I had it checked out and new keys programmed for it. Still have nothing, and I get no beeping when you put landward on. Seem like I’m not getting any power. Help
Did u check all 3 fuses. There’s one by your solenoid. Also make sure your small red wires to your solenoid are on the correct post.
Don’t worry about the lanyard yet. If you push the start button with it off the gauges should still power up. If everything is dead you need to check all connections, fuses and trace to see where you are and aren’t getting power.
Yes all is dead, I will check all connections, thanks
