97 gsx dying at 1/2 to full throtle
97gsxseadoo
it acts like it's not getting the gas have never been into the carbs ,last year it would be hard to get to start when the fuel got below 1/2 tank would have to choke it to get it to start but would run perfect after it started,fuel lines have never been replaced,it was running perfect all day until it got below 1/2 tank yesterday would start up fine but was acting like it was not getting gas at 1/2 to full throtle would start to die let off gas throtle and would start running fine again:banghead:driving me crazy any help would be appreciated much:drool5:
I would start by replacing the gray fuel lines if is equipped with them. Then clean the carbs, as it sounds like you may have some debris in them. Check the fuel strainer in the tank and be sure all is clean.
Karl
thanks karl for the info, new to this seadoo fourm trying to figure it out. i pulled out the sending unit over the winter it had stoped working and fixed the f1 fuse on the board.maybe some trash got in the tank .
