GGuillot
When do get to the diode, you'll need to at least clip one end of a diode from the board to check it. Checking it still soldered to both points won't work, you'll get an inaccurate 'shorted' indication. Clip one end then check. If it beeps, it fails. On the fuse slot, with the fuse out, one side will be hot (voltage) and the other not.
