Hi!, new to the forum and seadoo's. Just got a 1997 Seadoo explorer with a 717 engine. It was running pretty good but idling low at first. took it out a second time and sucked up a rope in the jet. It ran for a little while after and then stalled out and wouldn't start back up. I noticed the engine was a little hot. Brought it back home, I changed the dry black plugs and cleaned out the carb. It fired back up but runs rough at low rpms (vibration) but fine at higher rpms. It will stall out if you let it idle. I was wondering what might be the problem. Would the engine overload offset ignition timing? I fooled around with the low speed adjustment on the carbs and it helped a little to smooth out the low rpms. Would love some advice on what you all think could be the problem. Thanks for your responses. This is a great forum to learn more about these fun machines.:cheers:
