ok, i'm still trying to start this rebuilt engine that i installed in a 97 challenger single. When i try to start it i get 2-3 cranks that last 5-10 seconds before the starter just makes a clunking sound and won't turn the motor. With the plugs out the motor cranks fine. The battery is a one year old autocraft marine group 24 with 500cca's. I took it back to the store they tested it and said it was ok. I also load tested it and it tested ok. The starter is SBT high torque probably 1-2 years old. Tonight i cleaned the starter ground, used di-electric grease hoping this might be the problem.
Something else, i hook up an inline spark tester that has a light. When i first crank the engine no light, no spark. After hitting the start button a few times i start to get spark, but not enough cranking and spark to start the engine. Then i have to wait or charge the battery again to get a few more cranks out of it. Any help, thanks...
