I'm close to Irwin. SE of Da' Burgh'.
I don't remember if those carbs had the accelerator pump or not... but if they do... a few pumps of the throttle handle should get it to fire.
Also... a primer isn't considered a band-aid by most people. When these carbs sit for a long time, the pressure bleeds off, and to get a shot of fuel from them requires some pressure to fill the carbs. But the stock pumps should do just fine. Anyway... a primmer has the ability to draw fuel up the line, and just squirt a little in the engine(s), and in turn, will make them pump the carbs up without having to crank the engine for 10 or 20 seconds. I personally put primers in almost everything I own, with the exception of my old super jet. It can sit all winter, and fire with about a 2 second hit of the start switch, and I never use the choke on it. But... as I'm typing this... I have a primmer sitting on my desk going into the 90 Si project sitting in my shop.
Now... is your hard start just after it's been sitting for the winter, or does it happen in a weeks time?
Last thoughts... a low pressure pump will get some fuel up to the carbs, but it may make a restriction in the line since the SBN carbs recirculate fuel back to the tank. Also... unless you are producing "Pop-off pressure" levels, you will still have to crank the engine to build pressure, to feed the carb.
Give us an idea of the hard start time frame, but I vote for a manual primer.
