New here, read many posts and have a list of things to check but here is where I am at. Ski has been sitting for years but it started and ran. Idles good but wont accelerate smoothly to WOT. However, after I got it past the dead zone it blasts off and ran without missing a beat for about 1/2 an hour. Figured it was carbs so I rebuilt them but the problem is the same with an added issue. Now it seems the rev limiter might be kicking in. Today I could not get it to run WOT for more than 100 yards. It will run a consistant RPM banging out I call it and idle fine. I got it to accellerate a time or two and it is strong till it goes to banging out. My fuel light is on with the tank full, would this cause the rev limiter to engage?
-It appears the fuel lines are new but I will check the fuel selector.
-I will chedkthe tightness on all the fuel lines
-Sounds like the rave valve might be an issue and I will look at it but honestly I do not know what I am looking at.
-Does this sound like the rev limiter or fuel related?
-Can I disconnect the rev limiter to eliminate it as a cause? I do not know what it sounds like when one engauges.
Thanks, Kevin
Thanks, Kevin
