96 xp problem
sand blast
i have a 96 xp that runs fine unless full speed, then dies but nrestarts easily and runs fine at 3/4 throttle....any suggestions?
Just dies......... will restart!
Water in a carb can stop gas flow.
Unplug the connector for the lanyard post and clean it, then clean the inside of the lanyard itself. Then try it again. You can also clean, dielectric grease, and test all fuses, wire connectors, and grounds, unplug the magneto connector plug and clean it too. Hopefully you just have a corroded terminal somewhere that is breaking contact. If not.
Besides grounds, fuses and fuse holders, the main places to be concerned with are the innards of your coil box, and all igniton related connectors, including the stop start switch and lanyard post, mpem, cdi and coil connector.
Worst case senario is a bad ignition pickup in the magneto housing that may be broken or is covered with metal debris and is getting shorted out
Unplug the connector for the lanyard post and clean it, then clean the inside of the lanyard itself. Then try it again. You can also clean and test all fuses and grounds, unplug the magneto connector and clean it too. Hopefully you just have a corroded terminal somewhere that is breaking contact. If not, more diagnostic work will need to be performed.
You should be useing BR8ES *plugs, gapped .021.
Besides grounds, fuses and fuse holders, the main places to be concerned with are the innards of your coil box, and all igniton related connectors, including the stop start switch and lanyard post, mpem, cdi and coil connector..
Worst case senerio is a bad ignition pickup in the magneto housing that may be broken or is covered with metal debris and is getting shorted out.
A free floating piece of metal inside the mag housing can short out the system regularily, or irrregularly, depending on what it touches. If it is not a broken gear tooth or starter shaft spline, it could be a piece of the centrifical weight holder retainers inside the bendix, as they break off regularly and there are 6 of them. They are U shaped and about 1/4 inch long x 1/4 inch wide. Not only a huge hazard to the destruction of the stators coils, but also a hazard to the ignition pickup by gounding it out killing spark and the power to everything else.
Thanks i will try cleaning connectors and fuel treatment and let you know Thanks again
