Had trouble with this XP last season, fouled plugs, wouldn't accellerate, bogged down, etc.  After reading this forum I tried cleaning the carbs, changing the gray fuel lines, cleaning the fuel valve, filter, etc. with no success.  I winterized it and put it away disgusted, vowing I  would solve the problem in the spring.  Today I installed a freshly charged battery and tried to start it.  Clunk,   Clunk.
No cranking. I tested the battery, full. Pulled the plugs to see if it would crank with no compression. Youssers! It blue oil all over the engine compartment and me! Apparently oil is leaking into the combustion compartment while it is not running. What is wrong, and how do I fix it? Thanks.
