Brprxt215
I bought this project last week. I tested the ignition system per the manual specs. The only thing that did not test good was the ignition coil. I swapped the coil out of my good 96xp and still had no spark. I then swapped everything back and pulled the stator cover off and found it to be all rusted and had a ton of moisture. I cleaned that all up today and retested the trigger coil and the three yellow wires coming out of it. They all tested good per manual specs. I’m going to pull the flywheel so I can clean up the mag cover and the check to make sure the crank isn’t rusty and rip any seals. After I put it all back together and if it still has no spark would I be safe in assuming that it’s mpem/ dc-cdi related?
