biggal76
Just got this machine but had a cascade of problems since purchase. Machine was running good. Then started misfiring. I'd had a leaky VTS boot that caused the hull to fill with water. The hull had water in it for a few hours at most. I didn't realize that the rear electric box wasn't sealed and it was full of water for a long time before I noticed and dried it- probably a week or two. A couple weeks later, the starter solenoid went (likely due to being submerged in water and then corroding). I replaced it and it solved my problem. About a week later it started misfiring. It seems like an electrical misfire. I assumed it was the coil, especially since it had been submerged in the electric box, so after ruling out spark plugs as the issue, I replaced the coil but that did not solve the problem. It seems to get worse the more it runs (I rode it a little bit like that and it worsened and now as I'm running it to troubleshoot, it's getting even worse).
I've been reading on the forum. Seems like rectifier is next likely suspect. Since I have no tach, I am just assuming, but when I rev it, I'm getting about 13.2V. I've read anything under 13.5V means replace rectifier, but I'm not positive what RPM I was revving and it was misfiring as it revved. What else can I do with a multimeter to pinpoint my problem? I don't want to wait a week to get a rectifier, spend time installing it, and find out that isn't the problem.
