robin savell lloyd
I do not know if you are refering to banjo fiting. but anyways I do not think that the 1997 oil injection has them as they are found on older ski's :cheers:I think we are getting off the subject!!!!!!!!!!!!
I meant the fittings where the oil sprays into your engine. They are a ball valve with a spring and can stick.
That can allow oil to siphon into the motor while sitting.
Crank seals (inner) could be leaking but they normally drain pretty quick and the motor wont turn over with the plugs in. (hyro lock)
Good luck. hard to say without seeing.
What colour are your plugs?
