First post here, glad this forum exists.
I have a 96 XP that's worked fine for the 12 years I've owned it. Always just put the DESS lanyard key on the post, beep-beep, hit start. Always. Boat runs great.
This weekend, I started it on the trailer for a few seconds in preparation for launching. Then went to launch it. At the launch, the boat suddenly doesn't react to the lanyard, the DESS key. Nothing. No wakeup, nothing.
But, I stumbled upon a new behavior. If I press the Start button, wake up the electronics first, then it sees the DESS key, starts, runs, no issues. It's consistent, every time, this sequence works.
I checked out the DESS post connections with a multimeter, all works normally. I pulled the MPEM housing open, all fuses are fine, all connections look clean and solid. Nothing I can find seems out of the ordinary. Ran through the advanced diagnostics mode, no error codes. And, the boat seems to run normally after the lanyard's attached.
But a sudden behavior change in a system makes me a little nervous. Has anyone run into this before? Why would it suddenly not recognize the lanyard's on the DESS post unless the electronics are awake? Is it a problem, or do you suppose I can just live with it?
Thanks in advance for any help or advice anyone may provide.
