Austrian Rotax
hello everyone, I finally got some time on my hands to fix this issue, so I most likely it is a lean problem as the ski can launch from zero to WOT without any bog 95% of the time and once it gets to WOT RPMs then it will only hold those RPMs for like 8s and then the RPMs start droping by a few thousand, The Tempo fuel lines were all changed by the PO and I dont know what carb work was done as I didnt ask unfortunately. Only thing ive been doing is running a 45:1 premix with the oil pump to help stop the engine from burning up if its lean. I know the fuel is critical to cooling the pistons so I dont hold WOT long and once symtom comes up, I let off throttle to idle, the last compression check I did was last month and it was at 136-140. any ideas would be appreciated and also the ski is hard to start cold im not sure why. Once it is warmed up for a min it will start up instantly once warm.
The possible issues I think it could be are
-lean carb issue?
-RV clearance but I think this is very unlikely and rare, The PO used tc-w3 oil I think though, it was blue.
-water regulator?
Things I have done so far:
-inspected fuel filter bowl under hood clean
-changed spark plugs
-fresh fuel
-the Crank seals dont leak at all so I hope no vacuum leak
I just hope someone can pointme in a direction they think is most likely the problem according to the symtoms?
Thanks for any help
and sorry for the long write up.
-lean carb issue?
-water regulator?
-fresh fuel
Thanks for any help
