Chris488994
Hello I have a 1996 Xp with the 787 Dual carb RAVE engine. I bought it used and was sitting for 2 years before. I did alot of work to it listed below, but this is the problems I had after all my work and finally got it out to a lake.
It is hard to start when cold and then bogs and dies when you give it gas. Will start back up and idle then bogs on throttle up. If I (POP) pull the choke give gas and let go of the choke it will take off and run great. Lots of power good top speed and a blast to ride. As long as I keep the RPM's up it will run fine. If I let it go back to idle then ill have to POP the choke again and it takes off. Ran like that most the day then it didnt work anymore. Started to bog all the time. Sounded like the motor was trying to go but would just shake alot and knock. After a 20 minute ride back to the dock at a high idle, I got it back on the trailer. Reved up fine but wouldnt hit top end. I have read and read for hours online the manual and I dont know where to start.
Any help would be greatly appreciated.
Here is what I did to the ski before I even took it out for the first time. Everything by the book.
Before I even bought it I Checked the compression and Spark. Compression was 155 on both cylinders. Nice strong blue spark.
Drained the fuel tank. Put in some fresh gas and it started. Seemed to run pretty good on the trailer. Reved up and idled at 3000 RPM.
I did not want to take the chance of running it LEAN so I pulled both carbs and went through them. The carb filters had a little bit of dirt but not bad. The big round diaphragms were still flexable and the ones on the other side were as well.
Checked the pop-off and both needles popped around 43 PSI. My book says 38 +/- 10. Thats if I have the black springs but im not really sure what color they are. Definatlly a darker color. Pressure leak test held for over a minute at 10 and 20 PSI. Did the suck and blow test on the inlet and outlet and they showed a resistance but would not hold a vacuum. Book doesnt say. I dont know.
Changed all the gray lines on the carbs only and put a clear inline fuel filter. When I cranked on the starter the filter filled up pretty fast. With a good flow. Started it on the trailer and it ran pretty good.
Got it in the water and it runs like crap. Was hard to start when cold then bogs down when you give it throttle. If I POP the choke it will take off and haul but.
Please help me.
Please help me.
