Lee.Harrison
Someone contacted me about a seadoo spx they wanted to get rid of, long story short I bout it for 325 dollars, I cant believe this but this is now my 7th ski to rebuild and flip, I will be posting some updates on this restoration.
Diagnosis:
Its not locked up, had a little bit of oil in the cylinders, but its been sitting for 7+ years so I think thats acceptable since oil can slowly get past the crank seals over time. Has good compression around 140 each cylinder.
It turns over slowly and I'm thinking the ground cable is bad and getting a weak connection because I load tested the battery that I had and it tested fine, might be starter but maybe not, going to order a starter rebuild kit anyway. Its in okay cosmetic condition but has lots of mold on it, also going to check for spark tomorrow because it won't fire even with gas in the cylinders
More updates tomorrow
Diagnosis:
