flatline16
I have a spx that says 97 on the vin but the motor is a 587cc. I opened the box and it looks like 717 electronics! Is this possible. I think it really is a 97 ski the motor crapped out on the previous owner and they installed a cheaper motor. On some of the wires there are butt connnectors so some of the harness was modified.
It has a fuel and tach that worked until I installed a new hood. I installed the hood yesterday. I removed the butt connectors and lengthened the wire about 1-2 feet. I matched all the wires like it was before. I bumped the start button and nothing. The gauges dont work anymore. I opened the box to check the fuses and they are all good. I only removed the connectors. Any ideas on what to check? I have run out of ideas and gave up after a day of scratching my head.
Any ideas where I can find wiring diagram for a tach and fuel gauge? If not maybe you could snap me a pic if you have a ski with those gauge or You cna explain based off the info given
Harness 1 entering the hood yellow/red red and blk yellow to the tach red and blk go? (to the big abcdef connector?)
Harness 2 entering the hood 2 green, 2 purple those to the the oil and fuel
Off fuel gauge the red and blk wire go to the tach red and blk wire (2 pin connector)?
Thanks for the help.
