steveobc22
I have a 1996 twin engine speedster,I am having a problem with the engines boging down, runs a little ruffer than normal at idle and if i drop the hammer both engines will rev up to 6800 rpm for a sec then drop down to 4k, if i pull the port engine bask to slow the starboard will rev up to full throttle, acts like a fuel problem,also when this problem started the starboard tach got stuck at 1k rpm. After i plane out with 2 engines if i pull the port engine back the starboard will stop bogging and run wide open. Could this be the rectifier? and how can i test the rectifier, I read another post of a guy that had the same problem and changed the battery and that fixed his problem. Any ideas would be great, Thanks
