Just stripped carbs, repainted, rebuilt both with Domonic's kit #3 from seadoosource...these carbs look beautiful!
Go to turn it over and PTO (I believe is the side closest to the impeller) is backfiring. Runs like poop. Bareley holds idle and when I give it gas it gets worse (the backfiring). Little dissapointed and frustrated at the same time. Set high needles to zero and lo's to 1.25 turns on both carbs.
Checked lines....pours gas all over the place. Oh and checked plugs...they look good, no I did not perform a pop off test like I probably should have but if that's mandatory I will.
Any suggestions obvious or not would be appreciated.
Thanks
Thanks
