b_dolla44
OK,
So to start his off I just picked up the 96 challenger 787... I was told it was parked two years ago because it didn't get up onto plane easy enough and they got a new boat...(thinking it was impeller/wear ring related I picked it (VERY CHEAP:hurray
So, I get it home today and hook the battery up after charging a few hours...I hear a funny humming sound coming from the DESS post area... I remove the bucket and find the Noise coming from the fuse rea... ( once you kick the bilge on the umming stops. And it only does it the first time the battery i hooked up)????
At this point I decide to hit the start/ stop buttom .....nothing happens.... No clicks, no anything....
PS I did have 2 short beeps from the DESS when I fisrt started....
So I start checking fuses...
The only fuse I find blown in both fuse blocks was a blower fuse....
the Engine will crank over with the plugs removed while jumping the relay in the MPEM...
Any help????
Thanks in advance!
PS. 'm a well know member over at ************** but the greenhulk doesnt have much of a 2 stoke SeaDoo section....:blush:
Any help????
Thanks in advance!
