ape1972
Hello all,
I have very Odd problem!
I had recently pulled the motor on my 96 GTX for some maintenance. When I put the motor back in is when the problem occurred. I connected the oil lines but I had not connected the carbs yet. I turned th motor over to do a compression check. It turned over fine but when I tried again the motor locked up! Like I can’t even move it with a pipe wrench (lightly of course). I took off the pump, starter and rotary valve and still the same problem. It never fired up and I literally turned the motor over for three seconds max and no strange sounds or anything. Could it be hydrolocked? It haven’t been in water but I could really use some help!
Thank you all in advance!
