I have 2 1996 gtx seadoos. Both have not run for a long time 2002. Both had the base gaskets pushed out from not winterising. I pulled both top ends and installed new gaskets and tore apart carbs and cleaned.
Put all back together and they start great but up and running will fowl plus quick.
I have set oil pump at line mark and jets are ok.
If I pull crank case pulse hose off and crank it I get a lot of oil spray out hose.
Both macines do the same thing on fowling plugs.
Can the oil pump be stuck and making it get to much oil. It has seadoo oil in tank
Ray
Ray
