charles7552
Need opinions please, just changed wear ring, all pump bearings, seals. Runs much better less cavitation but still when punched from a stop will slightly cavitate catch up and will do this about 5-6 times over a period of 15-20 seconds before running correctly. Everything is sealed and torqued per specs also sealed around shoe. The impeller looked pretty good to me no pits or curls but one blade was slightly worn in the middle enough to not be straight across. Wondering if this could cause this problem. Want to be able to pull kids on board or tube. I have the 110 HP 787 engine had no problems with it...knock on wood...Any help would be very much appreciated.
Thanks
Charles
Thanks
Charles
