OK, I just got this jet ski and now panic'n. Had it out twice and having a blast until now. Had small jet drive issue and now this.
Ran great for about 4 minutes. Then died. here is the scenario:
* Install new battery (old one was weak)
* Just topped off
* Fired her up and off we drove for about 4-5 minutes... then bla... she dies.
Pull it in and start the following:
* Switched spark plugs
* Switched to reserve tank (don't know... just trying anything!)
* removed the fuel filter bowl and check (found full of fuel and pretty clean)
* Got some starter fluid and she fired but rough
* once running full throttle gave it like 2000 RPM with backfire occasionally
* Pulled the front plug wire and not much changed
* Pulled the back plug wire and it died all together.
* Got it running again and with some feathering of throttle, got er up to about 4-5000 RPM and maybe 20 or 30 kts but must not let her idle, at Idle she backfires and sputters and eventually dies.
* Found the trick to starting was Full choke, Full throttle and crank the heck out of it.
I'm new to this jet ski scene and really am not sure where to start. Any suggestions would be simply awesome!
* Just topped off
