Hi -
Put my '96 GTS in the water yesterday for the first time this year. It started well, idled fine, but won't go beyond about 75% throttle. It seems to bog down or flatten out above that level of throttle. Runs fine at lower throttle settings. At higher speeds it sometimes will waver a bit. Plugs look fine.
Must be a fuel issue of some sort but I don't have enough knowledge of these to troubleshoot well. I did check the fuel filter and that looks fine. The gas is last year's (with a stabilizer) and the ski does sit around a lot, so I added some STP fuel system cleaner to the 1/4 tank of gas to see if that might clean things up. No effect, though I only ran it for about 15 minutes.
Any tips? thanks!
Any tips? thanks!
