Replacing the upper section of exhaust pipe to the engine exhaust manifold. My question should I use any type of gasket sealer to the surfaces upon re-assembly or is just the paper gasket sufficient? Also do I understand correctly the 3 stainless exhaust bolts and the bottom nut is to be torqued at 35 ft. lbs.? Thank you for reading my post and ride safe.
Seaputt2
Seaputt2
