96 gsx sounds like a blender
abelg
i took my 96 gsx out yesterday on its 2nd run after buying it..
and upon throtle a noise like a 'food blender' comes from the rear..
wtf is it?
sounds like either your.
Pump needs oil
Pump bearings need rebuild
something odd is jammed in the impeller/sator area
pull the pump cone you should find oil
use a coffee filter to strain strain the oil. as it falls out of your pump. I'm sure you'll find little chunks of metal.
It sounds like a stick or something is stuck in the Jet Pump/impeller. Look in the rear of the jet pump for any obstructions. It would cause a vibration / Noise. If its clear it might be a bad bearing in the jet pump.
Karl
