96 gsx engine noise, recording attached.
fubada
Hi, Can someone listen to this recording and tell me if this is a typical GSX 782 noise at idle? I open the throttle for a few in the middle of the recording. I am concerned about the grinding noise, but I'm new to PWC and two stroke engines. The ski is attached to a water hose.
Thank you.
SeaDoo Rattle
There is some movement, back and forth, of the impeller shaft. This will tighten up when the ski is in the water, the pressure of the impeller against the water will eliminate the rattle.
Try taking the ski to the lake and see if the noise goes away. It may still rattle even in the water if the idle is set too low. The idle should be about 3000rpm out of water and about 1500rpm when the ski is in the water.
Lou
