I tried removing the springs and the raves opened up all the way. Still acted the same way but was "hitting" a little harder. It probably made it slightly richer but didn't show anything else.
On another engine build I did, I increased the bore's 12mm in size. That required a jetting change. Stock was rich which makes sense since thats a huge increase in manifold pressure.
I thought .5 would have had an effect. Good to know its not enough to matter in this case
I honestly don't know what's the deal with these carbs. I'm guessing the PO only knew how to hold it WOT.
Thinking about it. There was 2.0 needles with 16 psi pop off, low speed at 3 turns out, High speed at 1 1/2 out.
So that must have been insanely rich
One theory I have is that having the high speed open so much was allowing pressure to equalize before and after the butterfly.
Or someone used a wired to "clean' out the ports in the carb and enlarged them !
Also now Its better up to 1/4 turn of the low speed. After that its rich enough to flood it out and throttle response suffers.
I do know that 4500 is when the main jet comes on fully. I know that because I watched it happen on the trailer (in the water) with a mirror. Before 4500 there was just a small trickle coming out of the mains, after that I could see the stream coming out.
To distinguish when the raves come in I could set the screws in more and see if the power starts later on in the rpm. I wouldn't mind it coming on sooner than that or later than that. Its set at an awkward spot where its either on the power or off of it. OR its just my issue causing this
Running so rich it needs more air and gets it only when the throttle is opened that much.
Then again I am setting the idle to 3000 rpm or 1500 in the water. Wouldn't that require a significant throttle opening ?
One thing I do notice now is that the first start of the day causes the RPM to jump up and then settle down as soon as the chambers fill.
My theory is: excessive fuel is choking the engine with such a small throttle opening. Adding more air helps to offset it and when the throttle is opened enough it allows enough air to enable combustion.
