Hi,
First time having the ski out on the lake today after fresh rebuild.
It starts up and run's rough as if it was loading up. almost 4 stroking and the engine shakes.
I thought it would be synchronization and tried to set it again but even with it perfect there was no change in the way it ran.
I tried tuning the low speed and it had no effect.
Its as if the low speed makes no difference until its 3 turns out, at that point I can notice the difference.
But there is literally no tuning ability with the screw at all which leads me to believe there is something else going on.
When applying throttle its rough and the engine shakes up until it hits 3500-4000, (1/4 throttle) then it smooths out but still misses a beat every now and then.
Below that it seems like its missing on one or both cylinders evenly.
Same thing if its on the trailer or if its running on plane.
If I let the throttle fall and pick it back up it feels like 4 stroking until it clears out at 4000. I'm only applying enough throttle to get it to rev up to 4000. I'm not mashing it and backing off. Just applying it smoothly until its around 4000 and then backing off a bit to keep it at that RPM.
I haven't taken it past 4500, It seems to want to "take off" after that point and the engine isn't broken in yet so I'd rather not. But it has surprised me a few times so I had to back off.
The following are set according to the shop manual:
The carbs are stock except choke plate removal and primer install.
Carb's dipped and cleaned thoroughly.
pop off was 32psi.
stock springs.
1.5 needle and seat which are brand new.
Jets are stock.
high speed at 0
low speed at "it doesn't mater
" but set it at 1.0
Synchronized the carbs by eye and then fine tuned while running.
Oil pump synchronized with the engine running at 1500 then set to normal idle.
I'm also mixing 50-1 at the moment for break-in. Could it just be the extra oil ?
How sensitive is this thing to oil?
I'm not sure where to start.
Thanks for looking.
PS. One thing I did notice the very first time it fired was that the response was quick and smooth but that was with clean gas just from me priming the lines.
After the mixed gas went through and the oil injection system started to kick in, it didn't have that Zip.
pop off was 32psi.
stock springs.
Jets are stock.
high speed at 0
Thanks for looking.
