I have a 96 Challenger runs and idles great but has low power on the water. I have had the wear ring replaced. A friend looked at it a said it was rev limiting to 4500 RPM's and replacing the MPEM would fix it. (For this boat about $900) Is his assessement correct? Is so can these be repaired?
Also looking at a post from SEADOOSNIPE below it seems it could be in the tach or info center...ideas???
"One of the things I read about was the grey wire that is used for the communication of the tach. If it's pinched or grounded, it will let your pwc run for about 30 seconds before the mpem shuts it down. Also, if the wire is good, there a possiblity that the tach or info center is bad. This would require further testing.
There is also a special feature in the mpem to control the engine if there is low voltage. For example, if the volts DC drops to 8.9, the rpm is limited to 4480, if the voltage drops to 7 for 30 seconds, the mpem will shut the motor down.
Here's a couple questions for you. When you start, do you hear anything other than the 3 beeps? Please try again and be sure your hearing three and not 4 or 6. Does the info display signal any faults or errors? Also, if you can, with only seconds to spare, you'll have to be ready. Get a multi tester ready and as soon as you start, check the VDC (volts direct current) to your battery. You should have about 11.8 to 12.4 vdc before starting and somewhere in the 13.5 to 14 vdc while running."
