Browzee0080
Just wondering, if your not to use dry gas, is it ok to use SeaFoam? Also, would water in the gas cause back firing enough to blow the rubber exhaust hose? And does the reserve draw directly, unfilterd from bottom of tank or is it incorperated with the fuel sock in the tank? Cause it only wants to run on RES...........
