EmptyNestExpress
I swapped an engine from a 99 XP Limited to my 98 XP Limited. Replaced all seals and rebuilt carbs when I did it.
The issue is: When I go to start it, it cranks for a few seconds then stops and then restarts all while holding the button down. I put some fuel in the cylinders to get it to fire and it fired but the crank is weird. It is not a constant crank and I am not sure why it would do it. I am using the MPEM from the 98 with the 99 engine. I haven’t read anywhere that said I needed to change it.
Any ideas are appreciated.
Also, what is the trick to priming these carbs so I don’t crank until the battery dies.
