Hey I have an issue with my oil pump, the control line slipped off I have reattached it but it does not seem to go back after you release the throttle. Any fix ideas?
You have to turn the lever the correct way. In one direction the spring will slip off it's locator tab and give you no return tension. The other way will engage the spring and tension the return arm. Pretty common to wind it the wrong way.
