You don’t just press in new sleeves.
You have to evenly heat the aluminum cylinder to remove the old ones then install the new ones making sure the ports are perfectly aligned.
Then you have to deck the head surface to make sure it’s perfectly flat then bore and hone the cylinders to perfectly match the new pistons.
This is an experienced machine shop operation not an at home DIY.
