95 XP Oil Injection Pump Maint
Farescb52
I’m trying to catch up on maintenance for family acquired SeaDoo XP. I have a few questions.
What maint is required of the oil injection pump?
The small oil lines are in great shape. I drained the oil and refilled with new oil. Oil filter replaced but the only issue was removing air from the oil filter. Small air bubble in the top of the air filter. Do I worry about this small air bubble? See picture.
Is it possible to check the oil cable alignment on the pump without taking out the carbs completely?
This is my list of questions from reading forum and watching videos.
Pump alignment needs to be done with carbs on and throttle cable attached and adjusted. You will need a mirror to see the oil pump lever and align marks on lever and pump body
