95 XP low fuel light
injun247
Will the low fuel sensor prevent the ski from accerating? I'm asking because upon full throttle after a couple seconds it starts to bog down and want to cut off. If you back off the throttle it will idle on it's own. But if you continue to stay on the throttle, the ski will die out. So... does the sensor have anything to do with this problem.
I also completely unplugged the wiring harness to the fuel baffle and continued to have the same result.....some advice would be greatly appreciated, thanks!
Fuel Selector
Try this, pull off the middle fuel line from the selector switch and connect it directly to the reserve port on the fuel baffel. This will bypass the fuel selector. See if it runs O.K.
Do you have the grey tempo fuel lines?
Lou
