toothfairy6@aol.com
I have an 95 xp. What part is it when... when it's stored I get too much oil into the bottom of the motor. I'm still useing the oil pump not premixing. I tried crimping the lower gravity fed hose from the injector tank. Not crimped when I'm trying starting it. I pull the plugs and turn it over not much oil comes out of the holes. I charge the battrey up and clean oil off the plugs.It then starts. Runs rough for a min.lot's of smoke then seem's o.k.. Does this mean the motor will need to be torn apart? (crank shaft seals)? Should I get through this summer rideing it by. Premix 40-1 remove to oil pump shaft. Put the lower and upper hose going to the injector tank Together with i radiotor flush kit. Untill I'm ready to tear it apart.
