95 Seadoo GTS Power issues
Tjdavis3107
Hey everyone. I have a 3 seater 95 seadoo gts. Here is my problem, on left turns, my seadoo loses about 90% of its power. On slight right turns its fine but the sharper the turn the more it loses. Id say right turns lose about 75 percent of its power at its sharpest turn. Going in a straight line, the seadoo acts just fine. If I was to let go if the throttle for any reason, and then try to throttle again, it goes at anout 10% power for anywhere from 10-30 seconds before going full speed again. That same symptom SOMETIMES occurs after losing power in turns.
Now.. any advice or thoughts?
I would check the fuel pickup in the tank. Dome of the older ones actually had hoses that wend down in that would rot off but I am nit sure if yours has that style.
There was also some talk that the crab diaphragms could cause this on hard turns but I have never seen it happen.
Check that the throttle cable is secured to the bracket on the carb properly. We want to eliminate any issue there.
