94 XP - oil in hull
HavasuMike
It runs fine, but after coming home, I find oil in the hull. It's not just a few drops. I have to use a rag to soak it up.
Hi, my 93 XP recently had oil in the hull. It turned out to be a loose hose clamp on the oil return line to the top of the oil tank. The clamp was loose at the motor on the port side. Have a happy 4th. Ken
my 94 xp always has a little bit in the hull not too much but not enough working to go through the engine to find the problem.
