94 xp fuel and tech gauges
94greenXP
someone please help. so on my 94 xp the fuel gauge doesnt work. i check to see if it has power and it does. the thing is when i was mess with the fuel gauge i think i messed up the tech. it was working fine now nothing. it has power going to it also. i guess i need to buy two new gauges. and help with were to get them. the ski runs great. also on the fuel gauge the oil light never work and the bike doesnt beeb when you start it. thanks alot for anyones help
sweet got the fuel gauge to work. the magnet was in the bottom of the fuel tank. used a coat hanger to get it out. i didnt now what to use to hold the magnet in so i used super glue.
The temp sensor is between the spark plugs. It internally grounds at 203*-205*(over-heated motor) and then the beeper sounds. Take the wire off with ignition on and touch it to a bolt on the head to test. Your ski is non-dess and does not beep when you put the lanyard on.
The oil light should come on if the oil in oil tank gets low. The oil tank also has a sensor.
